1991 Ford Mustang Cold Sputter
STEVEN BARIL
  • 5 POSTS
I have a 1991 Ford Mustang 2.3. When I start the car, it turns over fine. It even idles fine for a few minutes, but then begins to sputter like it's out of gas. When I step on the accelerator, it hesitates and sputter's even more. I have to let it warm up for 5 minutes until it clears whatever is wrong with it. If I drive with it still sputtering like this, it won't accelerate, it just spits and sputters even more. I had Aamco run a diagnostic on it about 1 month ago, and they told me I need to have the O2 Sensor replaced. They want to charge me around $500 for an $80 MAX part. Should I buy the part and replace it myself, or just suck it up and let Aamco rip me a new one?
Jan 21, 2007 at 1:55 PM
INDYUKE
  • 416 POSTS
Buy it and replace it yourself! All you need is a special socket with a slot cut out of it so that you can unbolt the O2 sensor without smashing the wire going to it. They sell them at most any auto store, maybe even sears. Just take your new O2 sensor with you so you can get the right size.
Jan 22, 2007 at 4:23 PM
Suggested Repair
Replace the oxygen sensor yourself. Use a slotted O2 sensor socket sized to the new sensor so the wiring is not damaged.
Conversation Summary
A 1991 Ford Mustang 2.3 starts and idles briefly, then sputters and hesitates as if it is out of fuel until it warms up for about five minutes. A shop diagnosed a failed oxygen sensor and quoted a high labor price. The expert advised buying the sensor and replacing it with a slotted socket rather than paying the shop.
