c4 trans
TIML
  • 19 POSTS
I have a 1966 mustang.it has a c4 auto trans.i got the trans from a salvage yard.it shifts into reverse and from first to second but not to third.any help would be apreciated.thanks tim
Feb 14, 2006 at 3:37 PM
LOVESCARS
  • 359 POSTS
could be a 2 speed
Feb 17, 2006 at 12:32 PM
TIML
  • 19 POSTS
i thought it might be a 2 speed too .but when it is in d you shift down to 2 it doesnt downshift.and when shifting from 2 to d it doesnt shift.
Feb 18, 2006 at 3:55 AM
LOVESCARS
  • 359 POSTS
it's likely because the linkage is not in synch
Feb 18, 2006 at 7:49 AM
TIML
  • 19 POSTS
the linkage seems to be ok.it goes from park to r to nutral then to drive but when im doin 60 then shift down to 2nd it just stays the same .
Feb 21, 2006 at 12:34 PM
LOVESCARS
  • 359 POSTS
valve body in the trans? i assume you've flushed the trans system?
Feb 23, 2006 at 9:48 AM
Discussion summary
c4 trans
The driver has a 1966 Mustang with a C4 automatic transmission taken from a salvage yard. They report the trans will engage reverse and shift from 1st to 2nd but will not go into 3rd. In Drive, selecting 2 does not force a downshift and shifting from 2 back to D does not resume the expected shift; the linkage appears to move through P–R–N–D, and at about 60 mph selecting 2 produces no change.
Reported outcome: The poster did not report a repair or resolution; the problem persisted as described in the thread.
Read the original discussion
