backup lights not working
DMESIANO
.2001 ford mustang GT 50,000 miles, manual trans, v8 4.6
I had my transmission replaced by a very reputable repair shop. After the repair they can not get the reverse lights to work. They used the original switch and the trans was from the same model car? I have traced the wires and been under the car myself but I cannot find anything conclusive. One question i have is is there a relay along with the switch or is it just the switch? does anyone have any idea what to chheck?
Oct 27, 2007 at 8:08 AM
  • 75,988 POSTS
Check the engine control sensor located on the right side of dash and also refer to the EWD below
https://images.2carpros.com/forum/automotive_pictures/12900_mustang_reverse_light_circuit_1.jpg
Oct 27, 2007 at 8:36 AM
DMESIANO
Thanks for the reply. I can hardly read the diagram. do you have a clearer picture you can e-mail me?
Oct 27, 2007 at 12:10 PM
DMESIANO
I think I figured out the EWD, thanks. What does the engin control sensor do? If it was failing would anything else not work? Because as far as I can tell EVERYTHING else its working. Also what does the engin control sensor look like or hoew do I find it. And the big question..... what do I check for?
Oct 28, 2007 at 12:09 PM
