Any stang bros out there?
JIMBOSTANG
Ingition- has crank but wont start. Gauges at normal poistion but when release to ACC guages pin to right but fall back to normal position. Did OBD test no faults found. Does anyone have an answer??? Urgent.
1999 ford mustang GT 2dr convertible
V8 4.6L SOHC Automatic
May 1, 2006 at 9:23 AM
320HPPONY?
  • 24 POSTS
check and see if the fuel pump is running.fords are notorious for a inertia switch try and find it and see if it needs to be reset(usually in rear of car on inside of trunk driver side) maybe even fuel pump relay good luck man!
Jun 1, 2006 at 12:15 PM
JIMBOSTANG
Thanks for the response. found problem, battery plate shorted, replaced battery gauges went back to normal operation during crank. still had no start, found loose pin connector at main fuel pump. now everything back to normal.
Thanks again for response
Jun 1, 2006 at 2:01 PM
