Air Conditioning Blowing NO Air Hot or Cold
SARAHBH
I have a 98' Mustang - air conditioning seemed to be working normally when I used the cold air. I got back into my car about an hour later and now NO air comes out of the vents at all. Everything sounds normal, as if it did when the air did come out. So basically, I can hear it working, but no air is coming out any of the vents. The heat is also not working. Do you have any idea what could be going on with my car and if this is mostly likely going to be an expensive repair?
Apr 16, 2007 at 5:35 AM
MERLIN2021
  • 17,250 POSTS
try MAX a/c and let me know what you get. Also if you hear the fan does the air come out of the defrost?
Apr 16, 2007 at 8:23 PM
SARAHBH
no air comes out of the normal vents even when i put it on max. but... it does come out of the defrost and the floor. the heat works for the floor as well!
Apr 18, 2007 at 12:44 AM
