A/C Compressor Not Getting Power
DOMINIC H.
1996 Ford Mustang, 210,100 miles, 3.8L V6. My A/C compressor isn't getting any power. The fuse isn't blown and all of the circuits are good but it still isn't running. How do I get power back to it?
Jul 29, 2007 at 8:32 AM
SLOFING
  • 21 POSTS
The pressure switch could be bad, try jumping the terminals. If the compressor clicks on, you need to check freon levels, if they are ok, then replace the switch. If neither of them work get a wiring diagram from the 2guys link and trace for a break in the cicuit. Be sure to test the maxi switch too.
Jul 29, 2007 at 9:24 AM
DOMINIC H.
thanx i did just what you said and it works fine now. thank you
Aug 4, 2007 at 9:59 AM
