87 mustang fuel pump
BHURT
My mustang turns over, but it won't start. I just iinstalled a new fuel pump and relay valve but neither of them fixed the problem. When I sprayed gas into the carburetor it started and ran as long as I kept spraying, but as soon as I stopped it died. It worked fine last summer, but after letting it sit all winter it hasn't started yet this summer.
I just got some new info: apparently there is no power going back to the fuel pump. So, how do I fix that?
thanks
May 17, 2006 at 12:19 PM
320HPPONY?
  • 24 POSTS
I had the same problem with mine man.Try a few things.1----Inertia switch in very back interior of car on driver side of back wall,maybe under trim panel(mine doesnt have trim yet).
2----Fuel pump relay under drivers seat(mine had a wire that had pulled out of the harness)
3----wiring plug on top of fuel tank that runs fuel pump(mine was dry rotted and would make intermediate conact) You need any help email me at Good luck man!
May 17, 2006 at 2:46 PM
