2008 Ford Mustang DTC CODE P0172
MAASSASIN
Engine Performance problem
2008 Ford Mustang V8 Two Wheel Drive Manual
My chck engine ligt come on I took it to fordand found out my air intake had came loose, I fixed that and a lin a couple of days it come up again so I took the air intake off and cleaned it and my maf with air and checked all the vacum hoses and there all fine I hooked my sct 3 flash tuner to it and programed the computer with the program that sct put on it for 91 octane I have a k&m air intake throttel body spacer and mid cat back exhaust I told sct that also and they put it into the programer, but I cleared the p0175 code and now I'm getting a p0172 code any suggestins? thatnk you Robert Murray
Oct 3, 2008 at 11:33 PM
BMRFIXIT
  • 19,053 POSTS
Most likely MAF sensor was damaged in the process
good luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 3, 2008 at 11:55 PM
