2007 Ford Mustang slow takeoff
KIMBERLIHOUSEMAN
  • 2007 FORD MUSTANG
  • 4 CYL
  • MANUAL
  • 80,000 MILES
Why do I get no power when take off
Friday, May 28th, 2010 AT 6:55 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Friday, May 28th, 2010 AT 7:31 PM
Related General Content
