2007 Ford Mustang Engine won't strart
RODNEY_NEWTON
Electrical problem
2007 Ford Mustang 6 cyl Two Wheel Drive Manual
My 07' Mustang won't start, my first signs of my car not to function properly were when I was driving at night and my headlights weren't on, later my interior light would flicker and cut off. Then the car would car cut off, while driving. I preplaced the alternator looking for a better result but found that didn't work. Should I check my starter next since I can't get my engine to turn over?
Mar 24, 2010 at 1:28 PM
DGK
  • 10 POSTS
Sounds like you may have a loose or corroded battery terminal or a bad connection somewhere. Clean your battery terminals and test your battery while you are at it. Check also where the ground cables connect to the engine and frame. Also check the connections for the positive cable.
Mar 24, 2010 at 1:43 PM
