2007 Ford Mustang convertible top motor failed
2007 FORD MUSTANG
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARBL
The motor that powers the convertible top failed, either it has burned out or shorted. Don't know which yet.
Can the motor be disengaged so I can manually open and close the top. Right now its stuck in a partially opened positon.
Nov 4, 2010 at 10:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
are you sure the motor is getting power? i.e. checked fuses and relays.. also it could be the switch and not the motor at all. also i assume you know that the vehicle must be going no faster than 5 MPH for the top to operate.
i have not yet found a manual override for the top
Nov 6, 2010 at 1:14 PM
