2006 Ford Mustang Turn Signal Relay?
PBHKJH
Electrical problem
2006 Ford Mustang V8 Two Wheel Drive Automatic
I am trying to find the Turn Signal / Hazard relay on my 2006 Mustang GT Convertible. I found out the hard way that Ford incorporated the clicking sound into the instrument cluster. SO WHERE IS IT?
Sep 9, 2010 at 8:55 AM
ANDREWJUSMC
I am having a similar problem, and i was wondering if you figured it out??
Oct 26, 2010 at 10:34 PM
PBHKJH
Well, I found out from Ford that the Blinker/Hazard module is now integrated into the fuse block that is on the passenger side kick panel. I would make sure that is in fact it is not a bulb, replace them anyway it inexpensive. If you have a Shaker 1000 you will have to remove the speaker and amps to access one of the studs for the tail light assembly if it is on the right side.
Oct 27, 2010 at 4:44 AM
