2006 Ford Mustang electronic throttle control defaulted to
72,456 MILES • V8 • 2WD • MANUAL
GARY AYCOCK
what do i check to rpair above problem wont crank
Oct 11, 2010 at 1:21 AM
MERLIN2021
  • 17,250 POSTS
The problem is not clear, it is cut off, what did the ETC default to?
Oct 11, 2010 at 3:48 AM
GARY AYCOCK
it faulted to limp home mode...just had the ecu flashed and light is still on abd the car wont crank...idk what to do...
Oct 15, 2010 at 10:16 AM
MERLIN2021
  • 17,250 POSTS
I need you to explain what steps lead up to reflahinfg the PCM, and who reflashed it, were there any codes? The more info you give here, the better able to assist you we are!
Oct 15, 2010 at 5:44 PM
