2006 Ford Mustang cylinder head
2006 FORD MUSTANG
74,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCHLEBEN
I had to pull the cylinder head off because a spark plug was cross-threaded and it broke off. I took the head off but only removed the sprocket and chain off the cam. Held it the the guide with a rubberband. The book called for taking the chain off the crankshaft but i didn't. When reinstalling the head if I marked the sprocket and cam will that be enough to get the timing right? 2006 Ford Mustang V-6
Sep 17, 2009 at 5:41 AM
DOCFIXIT
  • 18,828 POSTS
It is not necessary to remove chain what your doing is good. Get someone to help hold chain while head goes on. Also new head bolts needed.
Sep 17, 2009 at 6:07 AM
