throttle doesn't work
2005 FORD MUSTANG
ALSUE123
Will start but the throttle doesn't work. won't rev up so whats the prob?
Feb 13, 2007 at 5:42 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,360 POSTS
It sounds like the throttle actuator is unplugged or has gone bad. I would start by reading the codes.
Next I would try a used unit from another car and replace the throttle actuator.
https://www.2carpros.com/articles/how-a-throttle-body-works
Cheers, Ken
Aug 3, 2017 at 4:12 PM
LAZYBOY31614
Engine Performance problem
2005 Ford Mustang V8 Two Wheel Drive Automatic 31,000 miles
When accelerating from a stop in my 05 Mustang GT the car suddenly jerks forward. The only way to describe it is that as you push in the gas peddle it takes further then normal to go and then it leaps forward. Like it skips straight to around 3,000 RPMs. What could the problem be?
Aug 3, 2017 at 4:12 PM (Merged)
MUSTANG87
  • 261 POSTS
if your car is still under warranty take it to ford and get them to check your trnsmission.if no warranty take it to aamco transmission if you have one in your city and get the trans checked out.im not sure what it is since im not test driving your car and cant see .but possibly have a tranny issue.but then again i cant test it so take it to a tranny shop.good luck
LAZYBOY31614
thanks for the advice but it turns out it was just a dirty throttle body thankfully. The only reason i found this out was because of me putting a new intake on.
MUSTANG87
  • 261 POSTS
thats cool you found it was only dirty tb and not trans.it would be sad if it was a tranny since your car is basically new .
AWWSAM
I changed the oil in the car now the car wont but hardly start and has a lot of grinding noises when it does. It also has no power. If it dioes get running it is grinding and squeaking and has zero power
  • 110,190 POSTS
Is the motor oil full? Were there any noises before this happened?
TSTROUP
2005 Ford Mustang V8 Two Wheel Drive Manual 18000 miles
My Mustang GT, 2005, has low mileage and was running on a two day trip just perfectly and giving me over 24 mpg, then I stopped at my destination.
The next time I started the car, about two hours later, I noticed the trip meter was reset to zero and then the message center displayed the "Failsafe Engine Mode" message and the car idled OK but wouldn't respond to the accelerator. The gauges read fine and no other message lights or warning lights came on. I limped it two miles to my destination. The next morning, it started and ran fine with no messages and no "Failsafe Engine Mode" warning. I drove it about 15 miles and all seems to be fine. What do I do next ? Will it hurt to drive the car ? In five days I need to drive it 1200 miles to my home and work location and I am not trusting it. What if it does this at 70 mph in the middle of nowhere in Alabama ? Thanks.
Aug 3, 2017 at 4:13 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Need to stop and have it checked
check for code s
should be 1st step
