2005 Ford Mustang Turn Signal problems
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLAYDSR
My 2005 V6 Ford Mustang, turn signal lights do not work on the RH side, I have checked the bulbs and they are all fine, they give no indication of not working inside the car e.g.they flash normallythey are not going any faster than normal, but outside do not work.
Sep 27, 2008 at 12:34 AM
BLACKOP555
  • 10,386 POSTS
check the turn signal flasher relay first and the wirings at it for corrosion. after that check for voltage at the turn signal not working with that light engaged, you getting any at all?
Sep 27, 2008 at 2:54 AM
