2005 Ford Mustang power windows
18,650 MILES • V8 • 2WD • MANUAL
EDDIEABRAMS
The car is a convertible and tne battery died. when we replaced the battery, the windows stop returning to full up after opening the door. Before - when you opened a door and the windows were up, the windows would drop down about 1/4" and go back up when the door was closed. Now they drop down when you open the door but do not return to full up once the door id closed. If you are inside you can do it manually but that does not help if you are outside the car.
Jan 31, 2009 at 6:32 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated
the manual says this precedure should not need to be done if the battery was disconnected .. but you could give it a try anyway .. you will need to skip the scan tool stage .. if this is not succesfull the car will have to be read by a diagnostic scanner to determine where the fault lies .. let me know
Door Window Motor Initialization
CAUTION:Make sure no obstructions are present in the window system when carrying out this procedure.
NOTE:A battery disconnect does not require this procedure to be carried out.
NOTE:Excessive bounce-back (bounce-back that occurs with no obstructions present) may indicate a non-initialized window motor.
NOTE:The front window motors must be initialized whenever: a new window regulator and motor is installed, a new window glass is installed, a glass top run removal and installation or when carrying out any operation in which grease or lubricants are applied to the window system. A new front window motor is in a proportional up/down mode until initialized.
NOTE:The convertible rear window motors do NOT need to be initialized as they do not have one-touch up or one-touch down functions.
NOTE:All front window components (window glass, window regulator, window motor and glass top run) must be installed and tightened to specification before carrying out this procedure.
NOTE:If this procedure is only partially completed, the front window motor remains non-initialized and only the proportional up/down functions operate. A non-initialized window motor may allow one-touch down operation, but does NOT allow one-touch up operation.
NOTE:If the one-touch up does not function after 3 attempts using the window control switch initialization method, especially if false bounce-back occurs, carry out the Door Window Motor Initialization using the scan tool.
Using the window control switch
CAUTION:Make sure there are no obstructions present in the window system when carrying out this procedure.
NOTE:The door MUST be closed during this procedure, in order for the door window motor to initialize.
NOTE:The windows must be in the full open position for this procedure to operate correctly.
*******Press and hold the window control switch in the UP position at the second detent until the window glass stalls into the glass top run. Once the top run is reached, hold the window control switch in the DOWN position at the second detent until the window glass stalls at the bottom of its travel.
Test for correct window operation by carrying out the one-touch down and the one-touch up features.
Using the vehicle communication module (VCM)*****
CAUTION:Bounce-back is disabled during this procedure.
NOTE:This procedure terminates without initialization if a corresponding window switch is pressed before stall is reached.
Carry out the window calibration (IP learn) using the scan tool.
After stalling into the header seals, the front windows move to the full open position.
Test for correct window operation by attempting the one-touch down and the one-touch up features using the window control switch.
Jan 31, 2009 at 11:00 PM
