2005 Ford Mustang hesitation/misfire
2005 FORD MUSTANG
29,890 MILES • 6 CYL • 2WD • AUTOMATIC
SPIDERSTANG
I have a 2005 V6 Mustang with an added but never used ZEX nitrous oxide kit and an aftermarket Dynomax dual exhaust. I have just recently noticed a slight hesitation or misfire from the engine while the car is in drive and the brakes are on. It feels as if the misfire or hesitation is comming from the drivers side of the engine. Normal performance while driving and accelearting does not seem to be affected.. Any suggestions on what might be causing this ??[img:972dfd23ed]http://www.2carpros.com/forum/automotive_pictures/194759_carandcats11_1.jpg[/img:972dfd23ed]
May 27, 2008 at 5:19 AM
MERLIN2021
  • 17,250 POSTS
Idle air control valve...
May 27, 2008 at 6:33 AM
DIEHARDAZM
  • 7 POSTS
try disconnecting your battery for at least 5mins to reset the car's computer. this may cure the problem.
Aug 17, 2008 at 9:16 AM
MERLIN2021
  • 17,250 POSTS
Diehard, I tink if you look at the date, it might be a clue, it's probably fixed by now??
Aug 17, 2008 at 9:18 AM
DIEHARDAZM
  • 7 POSTS
just found this site, sorry for not being a mind reader. i will surely try to be one in the future. and the only real mustang is a V-8
Aug 17, 2008 at 10:43 AM
