2005 Ford Mustang Changing Rear Brake pade
42,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIMMICH
I was unable to compress the caliper cylinder while changing the rear pads on the car. Unfortunately the cylinder has extended to where I can not get the caliper back on the old pads. Is there check valve or system preventing the cylinder from compressing?
Feb 14, 2009 at 1:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Should be able to watch this video will show ho to retract the caliper
https://youtu.be/j8YwfSKEzZo
Mar 8, 2021 at 5:10 AM
SQM
  • 6,383 POSTS
To get the piston back into the caliper you will have to use a special tool.
You will have to use the tool and line it up with the slots on the piston and turn the handle of the tool. This will allow the piston to go back into the housing.
Here is a helpful video:
I have attached the replacement procedure below.
Oct 8, 2021 at 6:52 AM
