I believe the anti theft warning light drains battery?
7,500 MILES • 6 CYL • 2WD • AUTOMATIC
ARISTOTLE68
Car only gets driven once or twice a week. I believe the anti theft warning light drains battery. Is there a way to make light stop flashing, or if it could be something else?
Thank-You very much for your time!
Jul 30, 2010 at 6:09 PM
SQM
  • 6,383 POSTS
The anti theft warning light does have the capacity to drain the battery, but it should take longer than a week.
Please note that every vehicle has certain amount of parasitic drain in the electrical system. Which will make the battery loose charge overtime and go completely dead after a certain period of time. That time will depend on the components of the electrical system of that particular car.
However many times you can have excessive parasitic draw/drain in your electrical system due to a faulty component. Like a glove box light staying on or a shorted window switch etc.
You can check and measure the parasitic draw by using a multimeter.
The Parasitic Draw (Current Drain) specification for your vehicle : Less than 50 milliamps (0.050 amp)
Here is a helpful video of how to do that task:
https://youtu.be/z5F7WpgjaRs
https://www.2carpros.com/articles/car-battery-dead-overnight
Aug 16, 2021 at 7:02 AM
