2005 Ford Mustang 2005 mustang
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLAYDSR
Guys you provided me with some advise regards my turn signal problems (no RH signal)
I can not locate the flasher relay I had to provide Forf with my VIN to get th eright one, the haynes manual does not provide a location, merely that the Smart Junction Box provides the signal etc.
I have checked that there is no feed going out of the SJB, but have not gone further ,I have put a feed into the lights at the SJB, all RH signal lights work ok, still need to locate the relay or feed into the SJB, any ideas
Oct 12, 2008 at 4:24 AM
DOCFIXIT
  • 18,828 POSTS
Hi claydsr
I can find no flasher it is all controled by the SJB. All I found was the hazard relay in center dash part #13D730.
What I did find was a symptom chart that describes your problem and some test equipment to pull DTCs to diagnose. Problem is a trip to Mr. Ford is in your future. Good luck
Oct 12, 2008 at 8:46 AM
