2005 Ford Mustang 2005 Mustang
CLAYDSR
  • 2005 FORD MUSTANG
  • 6 CYL
  • 15,000 MILES
Guys you provided me with some advise regards my turn signal problems (no RH signal)
I can not locate the flasher relay I had to provide Forf with my VIN to get th eright one, the haynes manual does not provide a location, merely that the Smart Junction Box provides the signal etc.
I have checked that there is no feed going out of the SJB, but have not gone further, I have put a feed into the lights at the SJB, all RH signal lights work ok, still need to locate the relay or feed into the SJB, any ideas
Sunday, October 12th, 2008 AT 11:24 AM
DOCFIXIT
  • 18,828 POSTS
Hi claydsr
I can find no flasher it is all controled by the SJB. All I found was the hazard relay in center dash part #13D730.
What I did find was a symptom chart that describes your problem and some test equipment to pull DTCs to diagnose. Problem is a trip to Mr. Ford is in your future. Good luck
Sunday, October 12th, 2008 AT 3:46 PM
