2004 Ford Mustang emergency brake stuck in engaged position
80,000 MILES • 6 CYL • 2WD • MANUAL
PAULCOXJR
The emergency brake lever pulls up and down very easily, so I know that this is the problem. Is there a quick way to disconnect the emergency brake so the car is drivable? and does the emergency brake go to both rear wheels or just one?
Dec 15, 2008 at 4:10 AM
JAMES W.
  • 2,394 POSTS
The emergency brake goes to both rear wheels. There will be a single cable that goes from the brake to a "tee" bracket under the center of the car. From the "tee" there will be a single cable to each wheel. With the brake lever down, pull rearward on the tee bracket and see if that releases the brakes.
Mar 11, 2021 at 6:28 AM
