2004 Ford Mustang Codes 172 175 & 182
2004 FORD MUSTANG
10,000 MILES • V8 • 2WD • MANUAL
LONGR2
Mach 1 Mustang. Throwing codes with only 10,000 miles. This car is garage kept. Still its driven but not like a daily driver.
Code 182
I changed the fuel pressure sensor with Ford OE part.
code 182 points to fuel temp sensor???
Cant find this sensor.
172 and 175 I thought would be coming from fuel pressure sensor not acting right.
Jan 21, 2008 at 6:26 PM
MASTERTECHTIM
  • 4,750 POSTS
172 and 175 is running rich on banks 1 and 2 which would lean me to possibly fuel pressure regulator. check vacuum hose to it and see if there is gas in it, that would be a tell tale sign its bad.
Jan 21, 2008 at 6:30 PM
FLEXY5
  • 512 POSTS
If I remember correctly, your engine doesn't have a fuel regulator, it has a pressure transducer. It should be located on the injector rail. It's a small box about 1" x 1.5" with an electrical connector on the top. I believer that the fuel temp sensor is integrated into the pressure transducer. If you have any other questions, feel free to ask and we'll go from there.
Dave
Jan 21, 2008 at 9:14 PM
LONGR2
[quote:b5f379af38="mastertechtim"]172 and 175 is running rich on banks 1 and 2 which would lean me to possibly fuel pressure regulator. check vacuum hose to it and see if there is gas in it, that would be a tell tale sign its bad.[/quote:b5f379af38]
Well I changed the pressure sensor on the fuel rail. I replaced with a new Ford OE part. Still have codes.
Should I disconnect the battery to clear all codes including keep alive memory. I was alos told fuel filter could also cause codes. Remember this car is garage kept and only 10,000 miles on it.
Donation will soon follow as i did last time just tight on money after buying this sensor.
Jan 22, 2008 at 8:23 AM
LONGR2
[quote:0b4c774686="flexy5"]If I remember correctly, your engine doesn't have a fuel regulator, it has a pressure transducer. It should be located on the injector rail. It's a small box about 1" x 1.5" with an electrical connector on the top. I believer that the fuel temp sensor is integrated into the pressure transducer. If you have any other questions, feel free to ask and we'll go from there.
Dave[/quote:0b4c774686]
Should I disconnect the battery to clear all codes including keep alive memory? I was also told fuel filter could also cause codes. Remember this car is garage kept and only 10,000 miles on it.
Jan 22, 2008 at 8:24 AM
