2004 Ford Mustang Brake Piston Reset
23,000 MILES • 6 CYL • 2WD • AUTOMATIC
STANG357
I am attempting to change my brake pads on my 04 mustang. I have followed instruction after reading a prior message concerning the resetting of the rear piston with a reset tool. I went out and purchased it, I am turning the piston clockwise per imstruction and the piston is not resetting. I spent ten minutes turning it to no avail. What could be the problem?
Mar 21, 2009 at 9:30 AM
BLACKOP555
  • 10,386 POSTS
are you pushing down when turning it? if you dont do that it wont move...
Mar 21, 2009 at 4:17 PM
STANG357
Thank you. I was pushing as turning for 15 minutes to no avail. I spent a large portion of the day researching the issue. After collaborating all of my findings, I found out how to resolve the problem. After watching a youtube video of a mechanic stepping me through the process. Though he wasn't teaching on a Ford, I heeded his advice and turned the tool counterclockwise. Not sure if he said this by mistake or some models actually compress in that direction. Either way I tried it. This in fact did retract the piston which based on prior indications was normal. For whatever reason, on the Ford Mustang rear callipar piston, you need to back the piston out (counter-clockwise) and then in (clock-wise). I found this out 9 hours later. The second brake took me 20 minutes.
Mar 22, 2009 at 4:01 AM
BLACKOP555
  • 10,386 POSTS
never had a counterclockwise, could depend on the way your holding the caliper also... glad to hear ouve found it out.
Mar 24, 2009 at 1:27 PM
