2003 Ford Mustang Wipers and Turn Signal
2003 FORD MUSTANG
55,000 MILES • V8 • 2WD • MANUAL
MACH1MUSTANG777
I have a 2003 Mach 1 Mustang.The windshiel wipers and front left turn signal don't work.The fuses and bulbs are good.I replaced the multi function wiper and turn signal switch but it did'nt help.Once in a while the wipers will take off full speed by themselves when the switch is off but I can't turn them on or off.
Apr 29, 2010 at 1:14 PM
MATHIASO
  • 1,209 POSTS
Hello mach1mustang777 Welcome to 2carpros You are dealing with a short to ground, before the grounding switch. (Because there is no blown fuse) or a short to power between connectors. And corrosion in connectors could be the problem. Before hunting for short, lets check the basics. In the battery junction box, there are 2 relays: Wiper high/low relay, wiper park/run relay. check those two.(one of them may sticks) If the relays are good, on the wiper/low relay side, there are 4 connectors before the wiper motor.( check for corrosion in those) On the wiper par/run relay side there are 3 connectors before the wiper motor. (Check those) look also for burn wiring insulator on that side. For the park /turn lamp left front, check the ground as indicated. Check for open between the switch and the bulb. here is the wiper diagram and its related connectors.
https://images.2carpros.com/forum/automotive_pictures/46384_0996b43f80247957_1.jpg
here is front left turn signal diagram . Check your email for those 2 diagrams
https://images.2carpros.com/forum/automotive_pictures/46384_0996b43f8024794c_1.jpg
Apr 30, 2010 at 12:26 AM
