2003 Ford Mustang Whining noise
64,000 MILES • 6 CYL • 2WD • AUTOMATIC
ELEKTRA32
I just discovered a whining noise coming from my car yesterday. It will whine at idle and when I slow down to make a stop, but not when I'm driving. I had the A/C on the whole time...so I tired to pinpoint where the noise was coming from and to my discovery it will only make it when the A/C is turned on, quits when its turned off. Any suggestions as to what might be the cause of the whining? Thanks in advance.
Jul 18, 2009 at 6:57 AM
RACEFAN966
  • 5,029 POSTS
Do you have a cold air intake system on it? If so then you just have to deal with it. For some reason the A/C hose rests against the intake tube and makes like a wistle or whinning noise. Hope this helps.
Jul 20, 2009 at 3:50 PM
ELEKTRA32
Thanks racefan966 for replying to my question. I do have a CAI system, but that's not the problem...wish it was that simple. I had my mechanic check it out and it turns out that my A/C compressor and clutch bearing is going out...just my luck. So, I got my answer...for the price of $600...yay me!! :P
Jul 23, 2009 at 12:04 PM
