2003 Ford Mustang safe to switch to synthetic at 22,000 mil
2003 FORD MUSTANG
22,000 MILES • V8 • 2WD • MANUAL
TYLERMAX
  • 17 POSTS
I know this question has been asked a thousand times, but I would like to hear it straight from the horses mouth, so to say. I found a mint condiiton 03 mustang terminator cobra with 22,000 miles on it. However, the guy said he has always used pennzoil in it. If I switched to synthetic could I start experiencing leaks? I only aksed because I used to have an LS1 camaro Z28, and I switched to synthetic after 86K miles and it starting leaking. I just wanted to know what your guys take on this was. thank you.
Aug 5, 2008 at 11:38 AM
BLACKOP555
  • 10,386 POSTS
should cause it to leak! with olde engines i dont suggest it, but with a newer engine im surprised it aint recommended to use synthetic, lots better for the engine. i would go with the reccommended oil, but synthetic wont harm ya!
penzoil makes synthetic by the way.
Aug 5, 2008 at 3:06 PM
TYLERMAX
  • 17 POSTS
did you mean to say "shouldn't cause it to leak?" because if not, you seemed quite enthused about saying "should cause it to leak!" but it's not likely to have any problems with leaking once its switched to synthetic with a mostly stock 03 cobra with only 22K miles, right? Also, what is the recommended oil for this car? is it that half synthetic motorcraft oil?
Aug 6, 2008 at 4:01 AM
BLACKOP555
  • 10,386 POSTS
shouldnt! sorry about that i really need a new keyboard.
ill check up what they reccomend right now!
Aug 6, 2008 at 5:58 AM
BLACKOP555
  • 10,386 POSTS
10w30, doesnt specify regular only, you should be able to use whatever you prefer. my friend runs synthetic is his 2000 stang gt.
and i run synthetic in my 87 and its never ran better.
Aug 6, 2008 at 6:10 AM
TYLERMAX
  • 17 POSTS
thanks for the info, I will keep this in mind when purchasing my new SVT Terminator Cobra.
Aug 6, 2008 at 7:46 AM
BLACKOP555
  • 10,386 POSTS
thanks for the donation, and have a great day! if you need further asistance dont hesitate to post back!
thats a very nice car by the way.
Aug 6, 2008 at 11:59 AM
