In order to retract the rear caliper piston, you will have to use a special tool.
This tool will line up with the notches on the face of the piston. Then you will have to turn the handle of the tool to retract the piston back into the housing.
Here is helpful video:
https://youtu.be/j8YwfSKEzZo
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
I have attached the pad replacement and piston retract procedure below.
Images (Click to enlarge)
Oct 8, 2021 at 9:03 AM
