2003 Ford Mustang fuel filter
JSMG2010
2003 Ford Mustang 6 cyl Two Wheel Drive Automatic
how do i change a fuel filter?
Mar 11, 2010 at 9:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Relieve the fuel system pressure.
Disconnect the negative battery cable.
Disconnect fuel line fittings.
NOTE
The filter may be secured in place with hairpin clips, duckbill clips, or push connect fittings.
Disengage the filter from the fuel filter bracket clamp.
Remove fuel filter.
Install fuel filter. Note the flow direction arrow.
Secure the fuel filter in the bracket clamp.
Install fuel line fittings.
Connect the negative battery cable.
Start the engine and check for leaks.
Mar 11, 2010 at 9:33 AM
