2002 Ford Mustang window
112,000 MILES • 6 CYL • 2WD • AUTOMATIC
DREW420
power window off track or somthing wont go down & hitting top of car when i close the door
Jul 12, 2009 at 3:37 AM
MERLIN2021
  • 17,250 POSTS
You need to remove the door trim panel, they have a tool to aid in removal, then peel back the weather barrier, then inspect for loose or missing window glass bolts, or stop bolt. Look in the bottom of the door for any spare parts.
Jul 12, 2009 at 3:49 AM
DREW420
thanx bro will do ... u know where i can get a diagram online to remove the door panel & that tool so i dont screw it up .. thanx again
Jul 12, 2009 at 1:58 PM
MERLIN2021
  • 17,250 POSTS
I dont have a diagram, just thiese instructions.
DOOR TRIM PANEL Removal & Installation 1. Using flat-blade tool, pull door trim panel accessory trim plate away from door trim panel at service notch. Lift door trim panel accessory trim plate away from door trim panel to release retaining clip at rear. Remove door trim panel accessory trim plate. Using a small flat-blade screwdriver, disconnect switch harness connector(s). Set door trim panel accessory trim plate aside. 2. Remove inside door handle pull cup. Remove trim cover, inboard from exterior mirror near "A" pillar. On models with premium sound system, remove door speaker. On all models, remove door trim panel -to-door retaining screws. Release door trim panel -to-door pin-type retainers. Lift upward on door trim panel. Remove door trim panel. To install, reverse removal procedure. All parts store carry the tool..
Jul 13, 2009 at 1:01 AM
DREW420
Got the panel off & did find a plastic thing with 2 plastic screws things on it ..it dosent look broke but i have no idea where it goes & how to put it back ..tried to figure it out for like 45 mins but im still clueless & looked online everywhere & dont see it
https://images.2carpros.com/forum/automotive_pictures/381134_my_mustang_005_1.jpg
Jul 14, 2009 at 5:24 AM
MERLIN2021
  • 17,250 POSTS
At the bootom of the glass, should be two holes one at the front and one at the back, they go through the holes and into the regulator(metal bar) that runs front to back. I did try to find a picture, but had no luck, maybe go to autozone and look though the manual for the car...
Jul 14, 2009 at 11:57 AM
