2002 Ford Mustang We have no idea whats wrong with the car!
SCHACON7665
Electrical problem
2002 Ford Mustang 6 cyl Two Wheel Drive Automatic
Driving along the street one day the mustang began to shake kind of funny then completly give out on us. We put oil, some gas, figured it was something trival. No dice. By putting gas directly where it should go the car would get enough to start but even by pressing the gas peddle did not continue and would die out within seconds. We have changed the fuel pump, the fuel line (thingy with all the wires above the fuel tank), we have changed the spark thingy and we are currently going to try and see if maybe it would have something to do with the relay. Would it? What other factors could play in a mustang not being able to recieve enough gas? The battery is good, infact it cranks forever and ever, just no start. Whats wrong with it?
May 7, 2008 at 8:18 AM
  • 75,988 POSTS
1st thing to do is -do a fuel pressure test to rule out the fuel pump, pressure regulator and fuel filter. if it checks out-start checking the ignition system components one by one, power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
May 7, 2008 at 8:51 AM
