2002 Ford Mustang v-6 mustang misses at a steady speed
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
JACOB2197
i have a mustang v-6 3.8 that only misses at a steady speed .the only time it misses is when you have your speed up,and are maintaining a steady speed.speeding up or slowing down ,,no miss....only when foot is barley pushing on accelerator to maintain a steady speed
Jan 24, 2009 at 10:53 AM
  • 75,988 POSTS
Engine misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 24, 2009 at 1:14 PM
