2002 Ford Mustang Tire Rod Ends
135,000 MILES • V8 • 2WD • MANUAL
MGRECO40
My car has a very slight pull to the left. I was told by the shop that i need a left side tire rod end. Because the onside is all the way tight and the other all the way loose. Does this sound right?
May 15, 2010 at 1:16 AM
  • 31,937 POSTS
Hi there,
The sloppy tie rod end will cause an alignment problem, this will cause the pull to one side, so get both fixed .
mark (mhpautos)
May 15, 2010 at 2:20 AM
