2002 Ford Mustang Starter system problem?
135,250 MILES • V8 • 2WD • MANUAL
RACEMARK5
My old battery drained while driving. The radio went dead and then the car quit running. No power to turn engine over. Would not jump start. Replaced battery, still no kick from starter. Did low battery burn up starter. Car will push start and run fine now with new battery. Thank you for any help!
Jul 22, 2008 at 6:19 AM
2CARPRO JACK
  • 11,533 POSTS
You need to use a test light and check for power at the small wire on the starter while key is in crank position. If no power, problem lies elsewhere, if it has power, the starter is bad
Jul 22, 2008 at 8:26 AM
RACEMARK5
Thank you very much for the advice. Power is there, so I am pulling starter now. Thanks so much!
Jul 24, 2008 at 5:15 AM
2CARPRO JACK
  • 11,533 POSTS
Glad to be of help
Jul 24, 2008 at 5:25 AM
