2002 Ford Mustang manifold pipe gasket weld broken
2002 FORD MUSTANG
KENIANJAKE
Engine Mechanical problem
2002 Ford Mustang 6 cyl Two Wheel Drive Manual 150k miles sounding like a tank again
Where it meets the catylic converter,Had the exhaust manifold pipe gasket welded (electric) and only lasted a month. Should I take apart again and ARC (gas) weld it? Or break down and buy new or used manifold with gasket factory welded?
Dec 9, 2008 at 3:02 AM
BLACKOP555
  • 10,386 POSTS
its gonna keep crackign from the heating and cooling cycles.
is it cast iron?
if so you have to have a good welder weld it and properly heat it and use the proper filler or it will keep cracking again.
Dec 27, 2008 at 1:29 AM
