2002 Ford Mustang engine
86,789 MILES • 6 CYL • 2WD • AUTOMATIC
JOE EATON
Engine cranks over good but will not start. it sounds like it wants to,still not starting.
Dec 25, 2009 at 3:22 PM
  • 75,988 POSTS
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 25, 2009 at 8:27 PM
