2002 Ford Mustang driver window
CINDYWARE
Electrical problem
2002 Ford Mustang 6 cyl Automatic 93000 miles
my driver side window in down and wont come back up. I can here a clicking sound but nothing will happen. Is there a fuse I should check or what shall I do? I don't have a manual to look this up
Jun 7, 2009 at 6:23 AM
MIKE H R
  • 3,094 POSTS
the fus is number 43 in the fuse box, it is a 20 amp fuse. The fuse would not be bad if the other window works , they work off the same fuse. The switch could be bad or the window motor is bad. I would look the window switch more than the motor. Here is a diagam of the electical circuit.
https://images.2carpros.com/forum/automotive_pictures/54223_Graphic_4.jpg
Jun 7, 2009 at 8:48 AM
