2002 Ford Mustang Coolant Leak
STRTRKKER
Engine problem
2002 Ford Mustang V6 Two Wheel Drive Manual 75000 miles
I had to jump a car today using my 2002 Mustang and after I got the other car to run as I un-did the cables I noticed that there was something leaking from the bottom of the Mustang. I then looked underneath I saw radiator fluid dripping down. I pulled the car outta my garage to get a better look at it and looks like it might be coming from a possible blown gasket. Is that possible U think? It isn't the radiator as that's dry and ok.
Dec 9, 2007 at 2:47 AM
MERLIN2021
  • 17,250 POSTS
Which part of the engine is the leak comming from? Top front, Top rear? Front near waterpump? Have a pressure test done and you will know what it is...
Dec 9, 2007 at 2:55 AM
  • 55,561 POSTS
It sounds like the water pump is leaking which is common, here is a guide to help you pinpoint the leak and I have included how to change the water pump out in case you need it.
https://www.2carpros.com/articles/car-is-leaking-coolant
Check out the images (below). Let us know what you find.
Aug 2, 2024 at 11:50 AM
