Friday, May 4th, 2007 AT 11:08 AM
I just purchased this vehicle. It has 64000 miles on it. It was in a flood at one time but there are only a few things that don't work. The ECM works fine. The check engine light is on, but the OBD II reads "No Codes". The wipers, power locks and horn do not work. We have checked all wiring to each item and there is power into and coming out of all switches but not getting to where it needs to be. Also, the clutch makes a whinning noise when engaged. I guess my question is. Should we replace the fuse block for the electrical problems? And does the clutch have a grease fiting that is easily accessible or may there be something else wrong with it? Any help would be greatly appreciated.
