2001 Ford Mustang vibrating engine
2001 FORD MUSTANG
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHELCIEPOWELL
I just recently had a used motor put into my car. Iyt came from a close friend who had a standard. We put the transmission and other parts attached to the motor and now the car will start and run but there is a horrible vibration through out the car. I brught it to a local machanic shop and all they can tell me is that the vibration is an internal prioblem in the engine but the engine was working before i bought it with no problems. Do you know what may be causing the vibration?
Oct 29, 2009 at 12:10 PM
  • 31,937 POSTS
Hi there, are the two ECU's compatible? also check the engine mounts and all the vacuum connections and the general tune, you don't have a crossed lead by chance?
Mark (mhpautos)
Oct 29, 2009 at 12:32 PM
