2001 Ford Mustang power windows
48,000 MILES • V8 • 2WD • MANUAL
WRAYLEFLER
I need to troubleshoot the driver's side electric window. I recently changed the motor and it will not operate. what do I need to check first.
Oct 11, 2009 at 2:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
was it working prior to motor swap? have you check basics? (i.e. fuses, wire connections)
Oct 11, 2009 at 2:49 PM
WRAYLEFLER
yes, it was for about 4 mounths. You can hear the a click, sounds like there is power going to the motor. the rest of the windows are working fine.
thanks for you help
Oct 11, 2009 at 2:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sounds like a binding window regulator. if fuse, wiring, switch and motor is good then regulator is all thats left. since you say motor is indeed getting power then we know the switch , wiring and fuse is good. you also replaced motor so that is good, suspect faulty regulator.
Oct 11, 2009 at 2:58 PM
WRAYLEFLER
thanks a lot for you help
wray
Oct 12, 2009 at 2:04 PM
