2001 Ford Mustang power windows
WRAYLEFLER
  • 2001 FORD MUSTANG
  • V8
  • MANUAL
  • 48,000 MILES
I need to troubleshoot the driver's side electric window. I recently changed the motor and it will not operate. What do I need to check first.
Sunday, October 11th, 2009 AT 9:39 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Was it working prior to motor swap? Have you check basics? (I.E. Fuses, wire connections)
Sunday, October 11th, 2009 AT 9:49 PM
WRAYLEFLER
Yes, it was for about 4 mounths. You can hear the a click, sounds like there is power going to the motor. The rest of the windows are working fine.
Thanks for you help
Sunday, October 11th, 2009 AT 9:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like a binding window regulator. If fuse, wiring, switch and motor is good then regulator is all thats left. Since you say motor is indeed getting power then we know the switch, wiring and fuse is good. You also replaced motor so that is good, suspect faulty regulator.
Sunday, October 11th, 2009 AT 9:58 PM
WRAYLEFLER
Thanks a lot for you help
wray
Monday, October 12th, 2009 AT 9:04 PM
