2001 Ford Mustang hope you can help out
60,000 MILES • V8 • 2WD • MANUAL
LINDNEJV
i have a 2001 mustang gt and when i bought the car it had some DTC codes...i got them and it was misfire in cyclinder 4 as well as nr 4 ignition coil short...and it was running lean in both banks...so i changed the fuel filter and the spark plugs along with nr 4 ignition coil...and i am still getting bank 2 lean as well as misfire number 4...and i really dont feel anything till i start diggin into the throttle to see how she runs and i dont feel it till i am in 3rd gear at about 25 thousand rpms moving up real fast in speed...other than that i dont feel much of a change...but i do smell a little oil being burned when i reverse or sitting at a light...
Sep 1, 2008 at 12:25 PM
SERVICE WRITER
  • 9,123 POSTS
What code numbers?
Did you check for a vacuuum leak around the intake at alll?
Sep 1, 2008 at 12:33 PM
