2001 Ford Mustang belt squeal
107,500 MILES • V8 • 2WD • AUTOMATIC
BSMITH.7
Engine accessory belt squeals upon starting, have replaced idler pulley. It seems noise was coming from there. by holding a screwdiver to to bolt the noise was originating there. Idler pulley replacement did nothing to quiet the squeal. belt looks good. Belt dressing spray does not help.
What is the next step reccommended to solve this problem?
Jun 28, 2008 at 4:54 AM
MERLIN2021
  • 17,250 POSTS
Replace the tensioner and the belt, save yourself the headaches! Also, with belt off, check the A/C pulley, make sure it spins freely, no binding or grinding!, can be the pulley bearing inside...
Jun 28, 2008 at 4:57 AM
