2000 Ford Mustang Shifter
125,000 MILES • V8 • 2WD • MANUAL
US09372
I have never had an issue with my clutch. It has been strong for 10 years. There have been times when I would be driving in reverse and than would not be able to shift it out of reverse easily and would have to drive back a little further in reverse and it would disengage and work fine. However, the other night the same issue happened and when it shifted out it seemed to go out off the gear track. The car is stuck in reverse. The clutch still works fine but only in reverse. I am wondering if this issue could be as easy as needing to replace the shifter? Any ideas.
Sep 13, 2009 at 2:51 AM
DOCFIXIT
  • 18,828 POSTS
Hi
You'r saying shifter stuck in REV? will not come out even with engine off? if yes to both then an internal fault has occured possibly with shift fork.
Let me know
Thanks for donate
Sep 13, 2009 at 7:12 AM
