2000 Ford Mustang Power door locks
50,123 MILES • 6 CYL • 2WD • MANUAL
DADANDAB2006
When I use the lock/unlock button on the driver's side, I can hear what sounds like a solenoid click under the instrument panel in the vicinity of the fuse block - but, the locks do not operate in either direction. I've checked fuse "number 19" and it is good. There was an aftermarket alarm system on the car when I bought it, and I have since disconnected that because of some intermittent problems. The drivers side lock has always worked until now, but the passenger side has never worked. I have removed the passenger lock switch to replace it and there is no switch there at the moment. Any suggestions?
Thanks.....
Oct 12, 2008 at 11:08 AM
RACEFAN966
  • 5,029 POSTS
What you are hearing is the door lock relays and gem module. So I would say that it is time to replace the door lock motors. If you need anything else let me know.
Oct 12, 2008 at 2:21 PM
DADANDAB2006
[quote:b037b2e8bc="racefan966"]What you are hearing is the door lock relays and gem module. So I would say that it is time to replace the door lock motors. If you need anything else let me know.[/quote:b037b2e8bc]
First - thank you for your quick response. My only concern is - It seems unusual that both lock motors would fail at the same time. They were working perfectly until this and it has all the symptoms of an electronic failure. Is it possible there is a relay or module that has failed?
Oct 12, 2008 at 2:45 PM
RACEFAN966
  • 5,029 POSTS
Yes it is very possible that is the problem with electrical it could be anything in the circuit to it. So with that said it could be the relays or the gem module or the door lock motor.
Oct 12, 2008 at 2:58 PM
LUKE1234567890
I have the same problem, I replaced the actuator but nothing changed. I still hear the clicking sound underneath near the fuse box. Were you able to find out what the problem was?
Sep 12, 2019 at 8:25 AM
This original post was from over 10 years ago so it is unlikely for them to respond. So the best thing to do is start a new post with your specific vehicle info and issue. Thanks
Sep 13, 2019 at 7:05 AM
