2000 Ford Mustang Passenger door wont unlock
92,000 MILES • 6 CYL • 2WD • MANUAL
HISTORY
I just got a 2000 ford mustang and everything has been going well untill i noticed i cant unlock the passenger door with my key pad or with the button from the inside. If i want to unlock it i have to open the door from the inside. once i open it from the inside i have to manually push the lock down to lock it again. when i push the key pad or the button it moves like its going to unlock but it doesnt come all they way up. how would i go about fixing this and will it be an expensive fix?
Nov 22, 2009 at 6:15 AM
HERC20002003
  • 11 POSTS
Sounds like your lock accuater went out. Does it make any noise went you try to use the button? I had the same problem with mine.
Nov 23, 2009 at 2:46 PM
HISTORY
It makes the sound like its unlocking and moves a little but then it wont go all the way up. But sometimes it does actually unlock or lock.
Nov 30, 2009 at 3:10 AM
