No Electrical Power
AMFMORGAN
My 2000 Ford Mustang is receiving no electrical power. I have checked the battery and it is fully charged, power is going to the main distribution block. When I turn the key I get no power at all. No headlights, brake lights, dash lights, radio, etc... All the fuses are good. Any ideas where to start?
Oct 5, 2010 at 1:01 PM
BLACKOP555
  • 10,386 POSTS
check for the 12v at junction block only put black lead on the engine for the ground instead of the battery. check this guide out.
Oct 5, 2010 at 3:08 PM
BAKING_GIRL
Engine Performance problem
1992 Ford Mustang 4 cyl Two Wheel Drive Automatic
My car has a had everything replaced..new engine, alternator, battery everything...and it will just shut off randomly whats wrong....?
Aug 17, 2019 at 10:41 AM (Merged)
AIRSOFTSOLDRECN9
  • 348 POSTS
There might be a kill switch in the engine fuse box. At high RPM's the engine will shutoff to avoid mechanical damage. It is possible this circuit has a short. Make sure the circuitry in your ignition system is proper, everything up to the ignition coil. Try replacing the ignition control module on driverside fenderwell.
OFFERLE84
We tightened down the battery cables and that seemed to do the trick but it happened again. We are now looking into replacing the battery cables and swapping out some connectors.
We are in the dark about what is going on so any information will be appreciated.
Jan 7, 2021 at 10:30 AM (Merged)
BMDOUBLE
  • 1,139 POSTS
It's very likely that you have an issue with the cables if the issue was resolved after tightening them. Especially if you have the aftermarket clamps installed on the ends. Here is a guide for battery cable issues, but don't hesitate to reach out if you still have issues.
