2000 Ford Mustang Losing coolant, white smoke
118,000 MILES • 6 CYL • 2WD • MANUAL
DIEGOC
I had a coolant leak between the radiator upper hose and the radiator. I changed the the hose, but still leaking then i changed the radiator and a new hose clamp but it still leaking, so i bought a screw hose clamp.It stopped leaking but yesterday i checked my coolant tank and it was almost empty i drove the car for a while and it wasnt leaking but there was a white smoke coming out the exhaust. My catalytic converter has a small hole and im not sure if thats why the white smoke is coming out the exhaust but I still losing coolant.
Feb 25, 2009 at 12:05 PM
DAVE H
  • 13,383 POSTS
have the cykinders compression tested ..suspect head gasket
Feb 25, 2009 at 2:10 PM
